Portable gantry crane procurement parameters
- Order time: 2023.5.23
 - Lifting capacity: 4 ton
 - Lifting height: 3 meters
 - Span: 5.5 meters
 - Working voltage: 415v/50hz/3p
 - Order content: 4 ton Portable gantry crane
 - Exporting country: Australia
This is the order for gantry cranes sold to Australia in 2023. The customer purchased one portable gantry crane with a lifting capacity of 4 tons from our crane factory, which will be used for material handling work in the mechanical equipment factory. The order was placed at the factory on May 26th and production was completed on June 5th. We will ship the product to Australia on June 27th. The atlas shows some details of the production process of portable gantry cranes in the factory. If you would like to learn more about portable gantry cranes and the latest prices for 4 tons of portable gantry cranes, please contact us. The current reference price for a 4-ton portable gantry crane is between $4200 and $5500
Advantages of Portable Gantry Cranes
- The portable gantry crane itself is a portal structure, and there is no need to build a steel structure in the workshop.
 - The width and height can be set by yourself, and the steel frame structure design is reasonable, which can bear the weight from 500 to 1000KG.
 - The transportation and assembly are convenient. The portable gantry crane can be disassembled and divided into several parts, which is easy to transport and can be assembled quickly, reducing installation time and cost.
 - The utilization rate of the portable gantry crane is high, the operating range is large, and there is no excessive restriction on the use site.
 - The service life is long, the structure of the equipment itself is stable, the steel material is of high quality, safe and durable, and the failure rate is low.
 - Strong applicability, used in many material handling places, such as warehouses, mold manufacturing, auto repair plants, mines, construction sites, etc.
 - Equipped with Vientiane casters, it can be used for mobile operations, and at the same time, it can be moved after lifting heavy objects, which is very convenient, reduces labor force, and improves handling efficiency.
The Other Gantry Crane cases in Australia
- 4-ton portable gantry crane sold to Australia in 2023
 - 1 ton portable gantry crane sold to Australia in 2023
 - Three 5-ton portable gantry cranes sold to Australia in 2022
 - 25 tons of MH electric hoist gantry crane sold to Australia
 - 15 ton European-spec Single Girder Gantry Crane for sale to Australia
 - 15 ton European-spec Double Girder Gantry Crane For Sale To Australia
 - CE certified 5 ton gantry crane shipped from China to Australia
 - 5 ton single beam gantry crane used in Australian machinery manufacturing plant
 - 25 ton single beam gantry crane is sold from China to Australia
 - Gantry cranes are sold to Australia
How to customize gantry crane from China
We are a crane manufacturer located in China, providing crane customization services to global crane customers. If you want to customize a gantry crane, you can leave a message on the website or Email: sales010@cranesdq.com, tell us the following information, and our sales manager will contact you:
- Lifting capacity (ton): __ ?( The rated capacity)
 - Lifting height (m):__ ? (Height from hook center to the floor)
 - Span (m): __ ? (Distance between rail center)
 - Lifting speed (m/min): __ ? ( Single, Dual, Variable)
 - Traveling distance (m): __ ? (The length of the rail)
 - Work duty: __ ? (How many hours a day? How many times an hour?)
 - What material to be lifted: __ ?
 - Industrial voltage: __ ? ( like :380V, 50Hz, 3ph )
