Rail mounted gantry crane for sale Uzbekistan for container handling, capacity 41 ton, 4+1 containers. Check rmg container gantry crane specifications now.
Project info of 41 ton gantry crane for sale Uzbekistan
- Brand :Yuantai Crane
- Types of Cranes:Rail Mounted Gantry Crane
- Date of Placing Order: 2021-06-24
- Date of delivery : 2021.12.22
- Transportation :Railway transport
- Payment: 30% TT prepaid, 35% TT completed main steel structure production, 30% TT before delivery, 5% TT installation completed
- Destination port: CIP Pitnak
- Destination country:Uzbekistan
- First contact:2015-3-21
double girder gantry crane 41 ton for sale Uzbekistan
Main Specifications of 41 ton gantry crane for sale Uzbekistan
Quantity
1 set
Product Name
Crane Model
RMG
Lifting capacity
41 ton, with no spreader, total capacity 55 ton
Crane span
32 m
Lifting height
15.2 m (4+1)container
Working class
A6
Power supply
380V,50HZ,3P
Crane control
Driver’s cabin control, moving with crane trolley
Color
Standard
Application
Outdoor use
Customized features of 41 ton rmg gantry crane
- 1, 1 spreader: brand Zhenhua 360-degree rotating and retractable 20-foot, 30-foot, 40-foot containers,
- 2, Single-pole sliding wire: 4x350m 1000A, including relays, etc. Sliding line color requires blue
3, Gantry Crane requirements:
- (1). The total lifting capacity is 55 tons, the lifting capacity under the spreader is 41 tons, and the lifting height is 15.2 meters. The span is 32m, the total cantilever length is 9 meters on both sides, and the effective cantilever length is 6 meters on each side
- (2). Lifting speed with full load 0~18m/min, no load 0~25m/min, trolley running 0~60m/min, trolley running 0~80m/min
- (3). Running motor , hoisting motor bearing , electrical Schneider.
- (4). The customer’s track model is P65, the control input voltage is 220v, the output is 48v, the total power is 283.6kw, and the maximum wheel pressure is 310KN
- (5). Install a 2T-27M maintenance hoist in SEW configuration (see reference drawings).
- (6). Safety requirements: phase sequence protection, anti-collision system, overcurrent protection, phase-misalignment protection, overload protection, lifting limit, running limit, grounding protection system, emergency braking system, sound and light alarm, operation monitoring System and standard monitoring system, high-rise safety fence, windproof boots, lighting above the driver’s cab and in the working area of the gantry crane, laser infrared sensors are installed in each movement direction, the trolley power supply 7-shaped frame is lengthened to accommodate the power supply pulley when the trolley is at the end of the bridge , Under the bridge and under the outriggers, the camera monitoring system is installed, the pedestrian passage along the full length of the bridge, and the manual rail clamping system. Safety sensors, PLC system. Anemometer, lightning rod.
4, Accessories:
2 sets of brake pads, 10 couplings, 5 washers, 5 lifting limiters, 5 carbon brushes, 5 emergency buttons, 2 electric control coil controller contactors, 2 spreader lights, 2 sets of bearings, 180m wire rope, 4 cab lights,etc.
41 Ton Container Handling Rail Mounted Gantry Crane Uzbekistan
