Production Capacity:
100set/Month
Payment Terms:
L/C, T/T, Western Union, Paypal
Application:
Gantry Crane, Bridge Crane, Single Grinder Crane, Small Crane
Type:
Electric Hoist
Sling Type:
Wire Rope
Lift Speed:
2~8m/min
Maximum Lifting Height:
>20m
Chain Falls:
2
Basic Info.
Model NO.
CD, MD
Certification
ISO9001:2000
Condition
New
Color
Base on Clients Request
Main Electric Parts
Schneider
Control Method
Pendent- Remote Control
Motor
Soft Motor and Double Motor
Hook
Forged
Load Test
1.1 and 1.25 Times
Trademark
Dongqi CRANE
Transport Package
Wooden Box
Specification
1t-32t
Origin
China
HS Code
84251100
Motor. Hoist Motor is a taper type rotor motor with braking; it is one of the best quality motors,which has bigg ertorque, so it can be adapted to moving frequently, the Maximum torque is 2.4-3 times than the rated torque.
>Gear Box: Hoist Gear Box has specially treated gears for high wear resistance.Each Geared Shaft assembly issupported on ball or roller bearings, to ensure smooth, low-friction operation.
>Wire Rope: Hoisting ropes comply with the exporting standards. The leading rope taken by the drum does not slipsideways when slack. The factor of safety, on the nominal breaking strength of the rope is six.
>Rope Drum: Grooved hoist Drum, seamless pipe of adequate length to be wounded in one layer and to provid epropersupport for the rope to minimize abrasive wear is provided. Drum Shaft resolves on Ball Bearings for ensuring smoothrunning.
>Electric apparatus controlling system:Model CD1 and MD1 hoist is composed of the contactor box,controllingswitch, cut-off limiter, the working voltage of controlling switch is 380v, 36V or 24V(safety voltage)
>Rope Guide: Rope Guide is in two halves, ensuring easy accessibility. lt encircles the drum completely so that therope may not uncoil even when the Hoist is in unloaded condition. The rope guides of our company is thicken anddilated, so that it is not easy to be damaged.
> Hook:The Hook Block is tested to 150 % of full load before assembly.
https://www.chainhoist.top/5-ton-monorail-electric-hoist.html
