360° degree rotating jib crane for sale. The full slewing angle of 360° degree rotating jib crane is one of Dongqi Hoist and Crane’s custom designed jib crane to meet your light material handling. Chinese 360° degree rotating jib crane is for sale good price. Check the Chinese 360° degree rotating jib crane now.
360 degree rotating jib crane for sale
360° degree rotating jib cranes of Dongqi Hoist and Crane
As a professional crane manufacturer, Dongqi Hoist and Crane is able to provide your types of custom design jib crane. The 360° degree rotating jib cranes is one of the made to order crane.
Dongqi Hoist and Crane is able to produce fully rotating jib cranes with 360° slewing angles of any size to support capacities up to 10 tones. No matter where you are going to use the jib crane, Dongqi Hoist and Crane is able to custom a solution to your lifting requirements.
Customized 360°rotating jib cranes
We use the latest in computerized design technology to render drawings as quickly as possible to ensure a quick and accurate quotation for our standard and custom 360° degree rotating jib crane solutions.
Having supplied rotating jib cranes in multiple industries for decades, Dongqi Hoist and Crane is used to adapting our jib crane designs to fit particular challenges which may be unique to your business or sector.
Optional for 360°rotating jib cranes
As for different requirements and rotating jib crane application environment, Dongqi Hoist and Crane is able to provide you customized design. The following is optional for your jib crane:
- Parking locks for added workplace safety,
- Galvanized finishes for longer lasting protection to the system,
- Spark resistant design,
- oist canopies for outdoor use,
- A choice of paint options.
Meeting your 360° degree rotating jib crane
Although 360° degree rotating jib cranes offer the maximum possible slewing angle, the full rotation isn’t always required to fulfil your application. If an obstacle is present that makes the installation of a 360° degree jib crane impractical, slewing stops can be added to ensure the jib’s arm doesn’t come into contact with anything else.
The slew can be operated by a push/pull motion or can be motor driven. Similarly, the hoist can run either electronically, manually or can be air powered when travelling along the beam.
Whatever your lifting requirements, Dongqi’s rotating jibs can be tailored to suit the task in hand.
Get your custom 360° degree rotating jib crane
360° degree rotating jib crane for sale. The full slewing angle of 360° degree rotating jib crane is one of Dongqi Hoist and Crane’s custom designed jib crane to meet your light material handling. Chinese 360° degree rotating jib crane is for sale good price. Contact us for more information on the Chinese 360° degree rotating jib crane now.
