0.5ton Surpo-Low-Clearance Electric Chain Hoists
1 viewsGenetics
0
Transport Package:
Strong Wooden Box
Payment Terms:
L/C, T/T
Application:
Double Beam Crane, Gantry Crane, Bridge Crane, Tower Crane, Single Grinder Crane, Lifting Platform
Type:
Electric Hoist
Sling Type:
Wire Rope
Lift Speed:
4.4m/Min
Maximum Lifting Height:
9m
Chain Falls:
2
Basic Info.
Model NO.
HHBB03-02L
Certification
CE, ISO9001:2000
Condition
New
Color
Yellow
Capacity
0.5-35t
Trademark
Dongqi
Specification
Alloy Steel
Origin
China
0.5t electric chain hoist
Advantages of ring chain electric hoist:
First, the overall performance of the motor is good, which ensures the safety and reliability of the use, and reduces the occurrence of the risk.
Two, the whole body structure is very simple. Electric chain hoist is convenient for installation, disassemble and maintenance, and has good maintainability.
Three, Low-headroom is best, effectively save space, without the restriction of narrow space.
Four, three in one drive technology offers excellent performance, high quality alloy steel lifting reducer, to achieve three reduction, stable running, long service life, reliable performance, avoid many disadvantages of CD long distance transmission shaft hoist.
Five, more unique innovation, the appearance of novel and beautiful, exquisite,light structure.
Components of the hoist
Shell: It is made of light aluminum alloy shell, light but hard. The cooling fin is specially designed to ensure quick heat dissipation with the rate up to 40% and continuous service. The integral enclosed structure is applicable to places like chemical plant and electroplate factory.
Side magnetic braking device: The magnetic core generator is the latest design which is featured for generating magnetic force. It allows instant brake as the electric power is cut off. Thus the braking safety while loading is guaranteed.
Limit switch: The limit switch device is installed where the weight is lifted on and off to make the motor to stop automatically so as to prohibit the chains from exceeding for safety.
Chain: The chain shall adopt the imported FEC80 ultra heat-treatable aluminum alloy chain. It can be safely used in poor environments such as rain, sea water and chemicals.
Hook: It is hot forging with perfect strength that is hard to break. The operation safety of the lower hook is ensured by its 360 degrees rotation and safety tongue piece.
Support frame: The loading support frame consists of two steel plates. Which is extremely sturdy.
Transformer: 24V/36V transformer device. This device is used to prohibit unexpectde accidents caused by electric leakage and guarantees the safe use while raining.
Electromagnetic contactor: Electromagnetic contactor can be used safely under high frequency.
Inverse phase sequence protecting device: It is the special electrical installation which controls the circuit not to work in case of wiring error in the power supply.
Push button: Waterproof push bush button is applied. It is light and durable.
Technical Parameter
Type
HHBB03-02L
Capacity (Tom)
3
Lifing Spend (m/min)
4.4
Power (Kw)
3.0
Rotation spend (r/min)
1440
Phases
3
Voltage (V)
220-440
Frequency (Hz)
50
I-Beam width(mm)
100-178
chain Standard
¢ 10.0
Net Weight/Gross Weight/ (KG)
233/254
https://www.chainhoist.top/0-5ton-surpo-low-clearance-electric-chain-hoists.html
Asked question
