1 ton overhead crane with China traditional single girder crane design is hot for durable quality, wide application and cheap crane price. Check 1 ton single beam overhead crane now.
LD Traditioanl Cheap Single beam overhead crane for sale – Dongqi overhead crane supplier
1 ton single beam overhead crane specifications
LD Type Single Beam Overhead Crane 1 ton Specifications – Dongqi 1 ton hoist crane single girder
Span of hoist crane
S(m)
7.5
10.5
13.5
16.5
19.5
22.5
25.5
28.5
Lifting height of hoist crane
m
9
9
9
9
9
9
9
9
Lifting speed of hoist crane
m/min
8
8
8
8
8
8
8
8
Trolley speed
m/min
20
20
20
20
20
20
20
20
Crane speed
m/min
20
20
20
20
20
20
20
20
Lifting motor of hoist crane
kw
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
Trolley motor
kw
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
Total weight
t
1.67
1.96
2.19
2.63
3.02
3.49
4.39
5.76
Max Wheel Load
KN
8.9
9.8
10.5
11.7
12.7
13.9
16.2
19.6
Track of hoist crane
P24
P24
P24
P24
P24
P24
P24
P24
Main dimension
mm
7.5
10.5
13.5
16.5
19.5
22.5
25.5
28.5
Rail top to main top
H1
490
490
490
490
530
580
660
745
Rail top to hook centre
H2
910
910
910
955
970
970
990
1010
Wheel base
W
2000
2000
2000
2500
2500
3000
3500
4000
Crane width
B
2500
2500
2500
3000
3000
3500
4000
4500
Hook left limitation
S1
796
796
796
796
796
796
796
796
Hook right limitation
S2
1274
1274
1274
1274
1274
1274
1274
1274
Main girder height
H3
550
550
550
595
650
700
800
900
Note: Control mode for ground operation. Contact us to learn more 1 ton single beam overhead crane.
Get a quote
How to customize crane from China
We are a crane manufacturer located in China, providing crane customization services to global crane customers. If you want to customize a crane, you can leave a message on the website or Email: sales010@cranesdq.com, tell us the following information, and our sales manager will contact you:
- Lifting capacity (ton): __ ?( The rated capacity)
- Lifting height (m):__ ? (Height from hook center to the floor)
- Span (m): __ ? (Distance between rail center)
- Lifting speed (m/min): __ ? ( Single, Dual, Variable)
- Traveling distance (m): __ ? (The length of the rail)
- Work duty: __ ? (How many hours a day? How many times an hour?)
- What material to be lifted: __ ?
- Industrial voltage: __ ? ( like :380V, 50Hz, 3ph )
